Midi Through
CorOS Version: 1.0.3
Describe your issue:
I have connected fx unit via midi to the QC. In case I have switched MIDI THROUGH off in the QC, a program change does work perfectly. In case I switch the MIDI THROUGH ON, it doesn’t work anymore.
  1. set midi through on and sent midi pc to external unit. You will see it will work.
  2. set midi through off and it doesn’t work anymore.
Similar issue here, turning on midi through seems to simply connect the in and out together and disable onboard midi messages. I emailed support last week but haven’t heard back yet.
Hey! Following up here alongside the other thread. Support is looking into this and will get back to you ASAP.
If anyone else needs troubleshooting please email support@neuraldsp.com. Thanks!
