MIDI Out stopped working after CorOS 4.0.0 update
CorOS Version: 4.0.0
Describe your issue: MIDI OUT preset assignments stopped working after update
  1. Assign any PC or CC to a footswitch or Pedal
  2. No MIDI message is sent through MIDI Out (DIN)
  • Midi Thru messages work flawlessly and QC transmits them downstream without any issue: so likely not a cable/connector issue
  • MIDI channel is correct (as said, it works if I use an external controlelr thru QC)
  • As downstream device, I tried both a physical one (Eventide H90) and my PC (with a MIDI dump software, using my Focusrite audio card as downstream MIDI device).
    • in the MIDI dump I can clearly see that Focusrite is seeing only Midi Thru messages
    • when I click or move QC’s switches/pedals, I can see QC transmitting the MIDI messages via USB, but they never reach the Focusrite via DIN connector
@cranio76 Try disabling ‘MIDI THRU’.
From the Quad Cortex User Manual 4.0.0 manual:
  • “MIDI THRU: MIDI Thru allows multiple devices to be connected in series, enabling them to receive MIDI data from a single common source. When enabled, Preset MIDI Out messages will be disabled.”
