Has anyone tried out the MIDI clock out and gotten it to work yet? I’ve enabled it, but it doesn’t appear to be syncing to any of the downstream devices that I have… Unfortunately the manual hasn’t been updated yet, so I’m hoping there is something that I’m missing. ![]()
Same here. Nothing coming out.
Turn off MIDI Thru on your QC =)
I should have known I was missing something stupid simple. ![]()
It’s not stupid, many are asking and just forgetting to disable MIDI thru. ![]()
This only works if you use the QC as your MIDI Clock master. If you use an external MIDI Clock, you need Thru switched on, otherwise the downstream pedals won’t get the MIDI Clock. However, this disables your ability to send CC or PC messages from your QC patches. Also, with the Thru enabled, the QC does not sync to the external MIDI Clock.
Hi, thanks for chiming in. Be advised: my input was specifically made to address the query at the top of this thread, nothing further.
Wishing you a great day ahead. Cheers.
