Midi CC# for Next and Previous Bank
I would like to be able to simulate every foot switch being pressed over MIDI CC#. From the manual It seems I can turn on the metronome, and control A through H. But Up and Down seem to be missing.
How are you able to turn a metronome on in the QC? There isn’t a metronome built into it…. Do you mean tap tempo?
Not 100% sure, but the way I understand the manual, you cannot do this directly. Apparently there is no CC for “next preset”.
You can select specific presets and maybe you can program something in your midi device to send a PC message that increments from the previous one.
Correct. Is there a way to open a formal feature request? This should be able to be built into the quad cortex and then triggered through a new CC command.
Thank you for your reply. Could you explain a bit further what is going on in your image?
There’s quite a few feature requests on improved Midi functions so you would need to check whether they cover your topic.
Thank you for your reply (and sorry for the delay on mine). I have a FCB1010 but with stock firmware. My kind of goal was to replicate most of the stomp-like buttons available on the quad cortex and keep it out of the floor. I think I understand your approach, to hardcode 8 presets on CC messages per bank. However then I guess I would have to have kind of a similar approach for choosing a scene for each preset.
Thank you, I haven’t played with it in a while and was doing the configuration manually for the time being. I would appreciate a SysEx file with your recommendations. Maybe I’ll better understand through them what are the capabilities and limitations of the QC in its current state.
Thank you! I will take a look into what you sent me. For now I’ll be patient and see whenever or if they decide to expand further the midi CC.
