Link two amps/captures together - use an exp Pedal to seamlessly mix between the two
Two amp blocks or capture blocks need to be placed next to each other. Touch booth of them for a couple seconds on the display → they get linked. At this stage nothing changes in the operation of the QC.
But now you have the option to set the exp pedal to mix between the two amps. replicating Kempers morph feature.
You can do this alereay by creating a mix lane with different blocks and crossfade between the lanes with the exp pedal.
yep,
do it with a highly distorted fuzz too, it gives awesome result
