Hello,
I use Ableton Live as my main DAW. Is it possible to sync Quad Cortex’s tempo with Ableton Live’s tempo? Just as an extra info, I own an separate audio interface to which the Quad Cortex is connected to with XLR/TRS cables.
Regards,
Joel
Hello,
Regards,
Joel
Hi, i’m also interested in that
@Bluejay99 Two places for you: check this more current thread for a solution that appeared to work Quad Cortex, MIDI Clock & tempo CC - #8 by Phil29
If you’re unfamiliar with how to set up the midi preferences in Ableton, here you go: https://help.ableton.com/hc/en-us/articles/209071149-Synchronizing-Live-via-MIDI
Have fun!
Sure. It’s called MIDI Clock. I’m doing the same thing - running preset and scene changes, Minivoicer notes and of course the MIDI clock.
