Best way to set tempo without MIDI clock
Hello everyone,
I’ve been using the quad cortex for quite a while and found it pretty useful so far. I use several devices with it mostly to send Program Changes and get to my desired Presets.
Is there any way to externally set the tempo of the quad cortex without using tap tempo or midi clock? Most apps don’t provide the option for midi clock (Forscore for the iPad, etc) and I don’t need exact synchronisation, but just the overall BPM set correctly.
Using CC#44 only works as a “tap-tempo” style controller. And the only other option I see is to create an identical preset for every single song and then set the quad cortex tempo control to “per preset”. Surely there has to be a better way to do this right? Can’t find anything in the reserved MIDI CC list though.
Thanks for any help,
Franz
