Is it possible to have the volume control only used on certain outputs
Is there a way to have the volume control to only work on certain outputs. so I have the XLR output 1 going to the PA and I want that to be a consistent level. and then I use the volume on the cortex to dial the stage volume amp up and down. at the moment it seems to only work for all outputs.
No, but there is a feature request of this:
The main volume on the QC is an attenuator and NDSP recommends to keep at 100% for best SNR etc., and tweak each preset/signal chain output for the desired volume. Otherwise, as 747 stated the feature request has been added and may be incorporated someday. Since there is a feature request already added, this request can be closed etc.
