Have you had success connecting any other devices to your iPhone? Not all camera kit connectors are created equally when it comes to the knockoffs. Have you tried one of Apple’s branded grossly overpriced connectors? @RJMiddel 's suggestion to set the input?
I don’t know ¯_(ツ)_/¯…does this look right? None of the VU move when I play in this screen connected to usb or not.
I’m using a usb-b (printer type) to usb-c adapter which works connecting the MBA and even an Android phone (which isn’t even supported by the QC).
I can connect the iPhone to the MBA using all sorts of cheap adapters, cables, and hubs, so I don’t think the Apple specific dongle is a must have.
NDSP says it is plug-n-play for iOS. It’s a powered, class c device that shouldn’t require the camera dongle.
I did just plug in my old Scarlett Solo AI and it isn’t recognized, either. On my last iPhone, it would give a message about “not enough power to use” or something like that.
NDSP is correct, the QC is 100% core audio compliant. I can connect either my IPhone or iPad Pro directly and use midi and or usb audio for backing tracks etc., no issues since day 1. I am guessing your adapter is not providing data and only power or something similar. I use the camera connection dongle from Apple which works perfectly with my IPhone and I use a usb-c multi use hub for my iPad Pro which also works perfectly.
Awesome, I’m not sure if you are looking for a USB-C adapter for the IPad Pro but if so, let me know and I’ll link the one I got from Amazon which works nicely for adding multiple I/O and works great as an audio interface as well.
