Is the upcoming update going to allow setting input levels for each preset?
not unless it’s a huge surprise they slip in; none of the info released so far indicates a change in that area
Can you not set the input level to low enough to avoid clipping on your loudest input, then add a flat gain boost block at the start of your chain on each preset?
I can’t find any mention of whether the input gain is pre or post AD conversion, but unless you have a huge difference in levels, it shouldn’t be a major issue?
