Hi all,
I am still unsure what the correct way is to set input level in the I/O settings. Do you keep it at 0 or increase it below clipping. I was wondering if it makes a difference depending on what amp you are using (Amp Models, Plugins, Captures)
I presonally leave it at 0. Never had to adjust it either way for any guitar/bass that I own.
If you want the models to respond to your guitar in the same way the real amp/pedal would, then I believe the input should always be 0dB.
There are always applications where you might need to alter it though (eg. using a mic or a synth etc).
