Import Gojira Amp Sim settings to Quad Cortex
Is there a way I can import some of the GojiraX settings to a quad cortex if I purchase one? I want to be able to reproduce the sounds in a live setting that I recorded.
Yes, you can use plugin settings and presets from the plugin on the QC/QCm as long as you own the plugin.
oh sweet that’s awesome. Yeah I own the Gojira one and the Nolly one. I’m planning to purchase a quad cortex probably next week.
Seconding this, you’ll be able to replicate your existing presets, as well as adding and re-ordering devices from the plugin how you see fit (i.e., Nolly overdrive > Gojira phaser > Gojira Hot > Nolly reverb) etc., along with built in devices too. So you’ll have even more options than you do now which is cool
This is so awesome that is exactly what I was hoping for. Is there an instruction set somewhere on how to properly import the amp Sims? I’m getting very excited about getting a quad cortex haha
You’re more than welcome mate! With regards to the loading settings, I’ve found this video which might be what you’re after: https://youtu.be/nu6ijJ3ZT9E?is=JuhhoCgpBMU3od7L
Honestly it’s ace to play about with, you’ll love the multiple rows options too as you can run amps in parallel for mega wide tone. I currently run the rust and hot amps from gojira for crunch, heavy, and solo tones in scene mode, have full control over parameters, so lighter OD settings for rhythm, then push it hard for solo, so you’ll get even more out of it. There’s a bunch of tutorials out there for getting started when you get your QC, looking forward to hearing your tones! :sign_of_the_horns:
