Not able to find any info on this subject in searches (No Mic/Inst switch in my quad cortex inputs)
I have searched the web and it says it is now auto sensed and knows its a mic, however the impedance doesn’t change. Does this happen automatically as well? Or do I need to change this for mic input?
If you have a more recent Quad Cortex, the mic/instrument mode is automatic like you mentioned. It is only manual on older models.
As far as impedance, that does not change automatically, and it only applies to instrument mode. So it shouldn’t matter at all if you’re using a microphone. On a QC Mini the impedance setting is not available.
Awesome thanks for the speedy response
i reckon for a mic you still need to switch On the phantom 48 V
Only if the mic requires it, I would NOT do that for a SM-57.
But yes if you have a mic that requires phantom power it needs to be switched on.
Thanks for pointing that out
