How to Connect the Graviton M1?
Hi,
I am looking at getting a Graviton M1 to control my QC (or Mini)… and by ‘control’ I mean, to change presets. I use preset mode.
Q!) Can you use MIDI IN to change presets on the QC?
Q2) Given the outputs in the diagram /pic below - what cable would I need to connect it to my QC to send MIDI?
Thanks!!
AJ
Cool looking midi controller.
I had to look it up. I would run the midi out to midi in of the QC mini. Would need a 5 pin to a headphone style midi cable
Looks like it’s on the side
On second thought you could just get a 1/8in trs cable and go from graviton to QCM. I didn’t realize those were for trs midi. Very cool
I had an m1 and you can use any of the trs Connections to connect the M1 to the mini. If you want to use trs1 and 2 for footswitches than a midi to trs cable would be good, if not you can just hook it up with a trs cable.
Great little device!
Unfortunately, my QC is in the rehearsal room right now, but if I remember correctly, you can also just do the whole thing via USB.
This is from the user manual.
I saw this about a month ago. What interested me the most was the XY remote. There are times I go out in front of the stage while performing to check sound, and found myself runnig back to the stage to kick in a solo. Not only will this possibly save me from breaking something, but I could also verify boost levels while I’m out there.
Long to short, thanks to this thread, I have one on the way now lol.
All I need now are more MIDI options for the QC!
