High noise floor on Capture, even the Factory Capture
Hi all, I experience for years of high noise (or noise floor?) from Neural Capture, either I capture myself/using the factory capture
For example, the Factory Capture “Aggi 751 1”, use it with the bass directly, you would hear the noise when you play every note, like they are sticked together.
many of the Aggi factory capture got this problem, and I found “Aggi 700 16” is without noise. Even I capture my bergintino super pre (clean channel), also got some noise
I wonder how to get a capture without such noise? very annoying after you listen through PA and speakers during live.
I put up the tracks here so you can compare, which just a bass + Capture , nothing else in the chain
Aggi 16 (noisy)
Aggi 1 (not noisy)
Add a Bergentino track (a bit noise)
