Neural capture problems
When I connect up my gear to make a neural capture of my amp, the tones that it makes are extremely loud, no matter how I set the amp or the input to the nano. I am using a condenser mic, through a preamp (for phantom power) to go into the nano. No matter how low I set the preamp inputs and outputs, the same extremely loud tones play. It’s way too loud to use. Can anyone suggest what the problem and fix would be, please?
Can’t you just turn down the capture block?
I think it is supposed to be loud, it should be as loud as the amp would be played at, just believe.
