Hi and Low Pass Filter for Neural Captures with Baked Cabs
I know the IR Loader section on the Nano Cortex already have low and high pass filter options, but I do not see a similar option for situations when not using an IR and using a Capture that already has a Cab baked in. That would be a desirable feature for me.
Bump, please, let’s make this more prominent :backhand_index_pointing_up:
yeah agreed, this feels like an obvious omission on the Nano Cortex. baked cab captures really need a basic high pass filter / low pass filter, same way the IR loader does. without it you’re stuck with low-end junk or top-end fizz unless you burn an extra EQ block.
global EQ isn’t a real solution and post-EQ shouldn’t be mandatory just to clean up a cab. per-capture HPF/LPF would be lightweight DSP and way more consistent. this would make baked cab captures way easier to use live and in a mix.
Well said, let’s hope they’ll add it!
