Assignable outputs to neural capture, ir block and post effects
The one thing i am missing on the nano cortex are assignable output blocks. I really love how it is laid out, but would love to see assignable outputs to neural capture, ir blocks and post effects. Many people (including myself) are running hybrid rigs - some outputs go to FOH, some to amp/mixer. The idea is as follows:
Each of the blocks (capture, ir and post effects) would have a output dropdown, where you could choose from OUT 1, OUT 2 or OUT 1/OUT 2. That way you could achieve in a single preset, that e.g. CAPTURE goes to OUT 1 or 2 or both, IR goes to OUT 1 or 2 or both, and post effects go to OUT 1 or OUT 2 or both. So a signal chain would look like this:
noise gate - transpose - capture OUT 1/2 ( capture is enabled to both outputs), IR OUT 1 (IR enabled on OUT 1, but disabled on OUT 2 which means signal is pass-through) and the same options with post effects. A little bit more hashed out version of this request:
This would be ideal, really hoping for this feature in the future. It would make the unit much more versatile and overcome the limited output and no split signal chain.
