Having Problem with saving the settings
Hi everyone, I am a new user with the Quad Cortex. I seem to have a problem to save my settings.
in Stomp and Scene Mode.
example :
Scene Mode -
Setting Amp Gain to 30% and Save in footswitch A.
Setting Amp Gain to 70% and Save on Footswitch B.
BUT
its still the same at Amp Gain 70% when I turned on Footswitch A.
am I saving it wrongly or is this common that the Gain for the Amp will be as how you last save it?
Or
Does it have a setting function which I need to set?
Please Advice
make sure the third option is not selected under settings->device options->scene bypass state behavior
are you long-pressing the parameter you want to change per scene? A small ABCD box should appear when you do that, to indicate that the settings will be scene-dependent.
so I hv to choose this setting?
not working. stress mode now heehhhehhehe
Try the middle option
this should only have an effect on the bypass state of blocks (as the name / description suggests) but not on any other parameters that get changed.
you’re right David, I misunderstood the question
You have to tell the setting it will be specific for that scene. You do this by holding your finger on the screen just below (in this case) the Gain text. A figure (A-B-C-D) will apear letting you know this setting is specific for this scene.
If you repeat this step, you can remove it again so the setting will be for each scene again.
Hope this helped.
