Gapless preset switching
I guess you can do the second half of that already though? Just save the scene you want as the default scene, then step through presets?
But that would be limited to the next and previous preset (and also to the default scene. I don’t want to change the default scene for every song, and I also don’t want to copy the preset for every song it is needed for, because than I have to edit all the copies I made if I want to change anything in it). If a song could consist of any scene of any preset it could change the way we use presets in a good way. Instead of building presets for particular songs one could build presets around a single amplifier (clean, crunch, high gain, dreamy) or dedicated to different playing styles (a slap bass preset with different scenes for really clean, slightly overdriven, really clean and subby, etc.). If you have to add a new song to the setlist you would just go by: “Ok it starts with a cleanish intro, let’s go with scene 4 of preset A. Next part is a slap part but is kinda djenty, let’s try scene 1 of preset D. For the following rnb’ish part I think scene 7 of preset B could fit very good.” and so on without the need to copy or edit anything preset / scene related. A change made to a preset or scene would automatically propagate to every song that uses it because the song just points to scenes in presets. The example is of course made up, but you get the point.
Just out of a weekend’s rehearsals and the gaps between presets are bugging me more than they used to. I work with one preset per song and scenes for different tones in the song. It’s great that scene switches are seamless but the non-seamless preset loading is quite obvious and jarring. More to the point they get in the way of segues between songs, or any situation where you don’t have the luxury of complete silence for a few seconds.
Assuming that full gapless preset switching is simply not possible because it’s too much strain on the hardware, a couple of thoughts of how the gaps could be made less annoying:
  1. Make the gaps shorter! Could the code for loading presets be optimised somehow? You’d still get an audible audio interruption and lose delay/reverb trails etc, but at least your new sound would be available to play sooner.
  2. Could a “freeze” type sample of the audio be taken at the point of switching and sustained while the new preset loads? Then either have this cut out or fade once loading is complete. It’s not a “true” spillover but it would at least cover the gaps.
Or, if fade out after load isn’t possible, fade it during the loading gap to fill the audible hole.
Just some thoughts for the dev team.
Even the lowly FM3 now has gapless preset switching. Let’s go Neural!!!
Yeah, I agree the way they use “inevitable” is strange.
The last fractal update eliminated perceived gaps between presets.
I have a triple rectifier head that has more lag than fractals FM9.
Maybe the executable part on the amp side are preloaded partially?
Idk. I’m not at all technically literate, but I can tell you that fractal is using less chips than NDSP and they’ve been able to cut boot times by over half - compared to NDSP.
Also, they’ve figured out seamless switching which has been huge for me.
I will say, the sound of the presets on the QC feel more produced / polished.
Even with the fx shortcomings - I find the lead presets feel more fun to use.
It’s not better per se, but it is notably different.
That’s why I won’t be selling either units. Both inspire in different ways… I digress.
Personally I think 4 amps is overkill and would prefer 2 amps with gapless switching.
Fractal does the gapless switching and complex signal chains.
More complex than helix.
I do not buy that this is an “impossible” request.
One more point about quad amps… I tried a couple presets out that utilize this and to me it wasn’t a “better” sound. It felt / sounded a bit convoluted or busy?
Maybe they should offer seamless switching as a mode? Letting us decide how the power is used / weather or not we would ever need or want the plethora of “extras”??
I can’t imagine people are looking at some of these options as a deal breaker…
Idk. Just thinking out loud.
Im wondering. Did the difference in sound you heard on the fractal. Was it always that way? Or did you notice a change in the tone after they introduced gapless switching. I dont and havent owned any of their stuff. So Im just wondering if introducing that feature compromised its sound. I experienced this with a much cheaper unit from a different brand. The more features they added compromised the overall sound.
As for the seemless switching to be impossible I would have to have someone look at the way the actual hardware works and how it wired. I think thats why they added the scene mode where you can preload presets and in that mode the switching is seamless. Though live (which i dont play live but even at home it would help) Not being able to switch from scene to stomp without touching the screen makes you kinda locked into the way those presets are. Unless I missed something.
So seamless switching on the fractal came in the last update.
There’s not been any decrease in sound quality. If anything since they moved to Cygnus - sound quality has only gotten better.
Also, they’ve worked out better CPU usage in terms of complex signal chains.
I can honestly say the changes made by that company have always been forward moving.
It’s not a bad idea for you to post in the features section to add “mode switching” toggles.
I don’t know if that’s already an ask or not. Not a bad ideas tho.
Thats really cool. I dont know much about the actual software and hardware on either side. Its cool the fm9 is so good. Unfortunately I cant afford another unit. As for asking for feature requests Id rather just see what happens. Last time I asked for something (more high gain amp models) It was scorched earth and I was basically told that if I cant get the sound I want with the amps and tools in the unit that its a me problem. Because I didnt really care much about capture tech, and the only way I was able to get new amps was to buy compatible plugins which some amps in the plugins are pretty close to what is in the quad cortex. I must say effects arent so important to me. I use reverb, delay and an overdrive but thats about it. If i had the money id buy an FM9 for sure and keep both. But im kinda locked into the cortex. I dont think its a bad unit at all. And my only regrets have been with the quality issues I had with my first unit. Maybe when its paid off there will be an FM10 lol.
Seamless switching could really be addressed at some point. Yes, scenes are a workaround, but they prevent the integration of new presets into your own set. When I find a cool preset from someone else, it is often not possible to integrate it into my existing presets so that I can use it via scenes.
In my opinion, a solution like the one from Line6 would also be conceivable. There, it was implemented in such a way that only half of the chain is available, with the other half being made available for the preload and spillover of the new preset.
Fractal offers gapless. I’ve really tried to raise the issue with QC not seeing the writing on the wall but my attempts were all erased.
I also notice that the QC takes 2X longer to boot than fractal.
I don’t know what’s happening at NDSP. Seems like they’ve put all their eggs into baskets that almost don’t matter at this point…
As an alternative it would be great if the reverb/delay tail wasn’t cut off when changing presets.
Another thing that I find frustrating about preset switching is how it handles expression pedals. I use my E-pedal as a master volume trim for all presets. As the QC changes presets, for a split second, it treats the pedal as if it were at full volume (toe all the way down) so there’s a brief volume boost. Because of this I have to run the volume pedal near its upper range or there will be a big volume jump during the preset change. I assume this is because it takes a few milliseconds for the QC to detect the expression pedal’s position and then assign it to the parameter.
This one got me too. It would be way better if the QC would leave the expression value alone while changing scenes (I imagine caching the value last used before the preset change was initiated and use it as initial value for the new preset could work)
There has to be a way to do it. Even my old Fractal AX8 changes presets faster and with no expression pedal glitches. The request just has to make it to the top of the pile. SOON, I’m sure. :wink:
I use the preset/stomp hybrid mode, with presets on top and stomps on the bottom.
I have certain presets that I don’t need to change presets, I just activate an overdrive pedal, or some other FX pedal.
Some presets I do use for clean and hard rock/metal sounds by having a dedicated footswitch to change between two amps in that preset…Almost like a channel switching amp. Amp 1 is a clean amp, while amp 2 is pretty heavy and something like a Friedman or Mesa. The rest of my FX in that chain, don’t need to change. I’ve got 4 presets built like this, for certain situations and even certain songs. But for about 90% of our cover songs, we play in a 4-hr set, I stay in one bank and just bounce around in those 4 presets.
FYI: I don’t like scenes either, I prefer the virtual pedalboard approach of the hybrid mode.
Yes, there are many ways to get around the problem of missing gapless preset switching. But all of them are complicated or ultimately prevent you from simply trying out presets and then quickly integrating them into your own setup.
:-1: 'm thinking its not the power of the QC but the capacity of the team development to understand what musicians are waiting for … :slight_smile:
Yeah but even that they did away with on the helix stadium. They didnt want to give up 50% of the dsp just for spillover and even they are using something similar to scenes for gapless switching. It possibly could work but at a huge sacrifice in DSP and an elimination of two rows.
Is that confirmed? There really hasn’t been THAAAAAT much info about the Stadium yet. They keep showing videos of the UI, but not any info about what the DSP really is, or detailed info for gapless switching, etc. For all we know the DSP might be pretty similar when all is said and done with the new amp models. It may have more DSP technically but the newer detailed models might consume the same percentage as the old ones do on the old hardware. Hard to say
