I’ve tried without success, and have searched the discord and the forums, and can’t seem to find the answer. Has anyone managed to send a MIDI CC command from the QC using a Boss EV 30 expression pedal, or similar?
did you turn off Midi Thru?
Brilliant. that works. Not sure what to do as I needed midi, through.
Unfortunately the QC does either midi out or midi though. You can’t do both together currently.
You’re correct. That is very unfortunate.
