As @nico2440443 mentioned this has been identified on our end and is being worked on. Please stay tuned for updates.
Add me to the list.
Big lag with Expression Pedal for volume, whammy and wah.
Hope it can be fixed.
Did this get a fix?
I think itās better, but not fixed yet for sure.
No latency (noticeable) after last update and using a Moog EP-3 with zero issues.
Same here I still feel latency with wah and whammy with corOS 1.3.2ā¦
I wish it can be solved soonā¦
I am also experiencing some latency with expression pedal here (CorOS 1.3.3) this issue needs a correction. Itās kinda difficult to handle such a latency.
Hi @EdaxNox and welcome to the community!
I am using a Moog EP-3 and not able to duplicate any latency etc. Have you tried to calibrate your EP following NDSPās directions? If so and you are still experiencing issues, please reach out directly to NDSP via email: support@neuraldsp.com and they will get you sorted.
@EdaxNox The latency is bad, itās there, itās virtually unusable -
the worst part - the developers at neuralDSP canāt sense it or are in denial of it
I emailed them directly as soon as I noticed the issue and they told me āhaha I didnāt really notice any but weāll look into itā
well then you shouldnāt be designing a musical product
no latency that YOU noticed. Compare it to a real true-bypass wah pedal and get five different PROFESSIONAL MUSICIANS to give second opinions on a direct comparison to absolute-zero latency true-bypass stand-alone wah pedal VS. a simple single wah pedal setup on the QC.
I do not for a second want to hear a Neural developer talk about how they ādidnāt noticeā - get in the lab and prove it, show me the results or just donāt even bother
Iām running CorOS 1.3.3 with a Mission Engineering SP1-ND expression pedal.
Compared against my Dunlop Wah Iām not experiencing any latency.
Might break out the oscilloscope a little later if this discussion gets any more heated! ![]()
@Chortler57 - Hey! Sorry to hear youāre having trouble. This has been resolved and we havenāt received any other reports about this so there may be something else going on if youāre still experiencing latency. Please email support@neuraldsp.com , it may not be the solution you want to hear but ultimately they are the only ones who can help you.
