Downloads Not Appearing in QC
Guys I can’t figure out what’s going on. I’m at the newest OS and when I download a preset it doesn’t even show up in the download folder or on the QC unit anywhere. Also when I click on a preset I download months back nothing happens it just opens up into a blank preset with nothing there.
Any suggestions?
Usually when that occurs, you likely have a filter applied. Remove all filters and you will see your downloaded presets in the Download folder (assuming you are connected / linked to the cloud).
Unfortunately that’s not the case. I’m trying a factory reset right now. Not sure if that will do anything.
It’s glitchy as hell. I have the same problem all the time. They’re just no where to be found and then they just appear one day scattered among “my captures” and “downloads” with no rhyme or reason.
Then sometimes it works perfectly. Idk what’s going on but its not just you. It’s a mess
Exact same thing happens to me all the time.
Same here. But when that occurs I go to my profile and it is there. Then I click it there once again and then it appears in QC.
This must be a bug!
D
I’m stuck with this bug too but have managed to get around it by using the desktop app which seems to sync downloads with the box.
To do this, I had to crawl around the loft looking for my old printer because the “USB” is actually a printer connection.
The crap old band wifi, no USB or Bluetooth are serious limitations to the QC. I can see myself dumping this for the next gen of Kempers unless they fix these.
I have the same problem to, some captures are stuck in Downloaded, can not get them to My Captures…
Huh? How old is your computer? Might be time for an upgrade. :wink:
There is USB connectivity on the QC. What are you referring to?
I’ve also experienced the delayed appearance of Downloads on the QC. No logical timing to it, either.
There is no such thing like a “printer connection”. It’s still USB (to be exact: USB 2.0 Type B) …
I could understand a switch to Helix or Fractal, but Kemper? Its a completely different platform / approach and I doubt they will go the modelling route like the others do with their next product.
Make sure the filter for what you’ve downloaded is correct, also there is a refresh button in the top left corner. When there is a new download, there is a little green dot. click the refresh button and it should then show up in your downloads. There are separate downloads section for presets and captures.
Once I paid attention to those things, I didn’t have any problems with downloads anymore, the entire process is surprisingly fast. Also, when I download something, I try it and if I don’t like it, I delete it right way, otherwise the folder will get over filled very quickly with junk.
Had this problem too where I had the green dot over sync icon but the downloads weren’t showing up on QC and CC and my account was disconnecting too… one thing not said here is make sure to disconnect VPN on PC if you use one. QC prioritize wired internet connection shared from Cortex Control over it’s own WiFi connection when available. I suppose it is to avoid sync issues.
Had the same issue, wasn’t appearing in downloads despite previously using it. Went on Cortex Cloud, found the original, which had a green tick next to it. Clicked the green tick and it re-downloaded to my QC.
Old thread, this issue was resolved in a previous firmware update. Please ensure you are updated in both QC firmware and Cortex Control as well as the Cortex Cloud app.
