I would like to leave an idea here in case you ever read it and think it is interesting.
In the survey I received the other day, I proposed a function that for me would be ideal to be able to play live with a single preset.
Double step on ABCDEFGH switches. This way you can have two Scenes on the same button, with LED color change and text and color change in the live view. Making a total of 16 Scenes in the same preset. Like a double layer. It is easy to implement and you do not have to modify the current layout. Since it would be a simple software and UI tweak option and would cost only a few bits of processing.
I give an example of how the option would look within the different effects when configuring. Sorry for my quality of photo editing. In this example you could choose between C1 or C2 to activate that setting. Maybe adding a different background color to the letter makes it clearer…
Then, once everything is configured, you step on its switches, choose which Scene is in each one and save your preset. So that when you call the preset it starts as you want. In this example I have only added a 1 or 2 indicator at the bottom right of each scene.
Example:
