Scenes A/B toggles (8 scenes becomes 16 scenes!)
Make every scene-switch an “A/B toggle” like mooer products.
This could double the number of scenes.
A B C D E F G H (first tap)
I J K L M N O P (second tap)
example: in scene mode,
tap on switch A → scene A
tap again on switch A → scene I
tap again on switch A → scene A
tap on switch B → scene B
tap again on switch B → scene J
tap again in switch B → scene B
The limit of 8 scenes might be due to the amount of memory (ram) the QC has. I would love more scenes per preset because 8 really isn’t enough for some tracks, especially when hybrid mode is limited to 4 stomps/4 scenes. Wish they would expand that stuff via midi
Having each switch be an A/B for two scenes might be a nightmare though. How would you return to Scene A if later in your set that footswitch is still set to B? Also would be tricky with how the display configuration. If there were more scenes it would probably make more sense to have that controlled with a midi footswitch.
There are sooooo many requests for this. Vote here:
