I got my QC last week. I have an aeros loop studio and a beat buddy pedal that I like to use.
I like to switch around quite a bit between the factory presets, and it is a bit of a pain to manually add the signal loop every time I change a preset. I suppose I could go through the mall one by one and save it in there,… Also a pain…
Anyone know if there is a way to improve that workflow? Just have the loop default on every preset?
I don’t see any way other than connecting your external FX to the output of the QC to have them working with all presets by default instead of using the S/R loop. Other than that, a default and global S/R loop doesn’t make much sense because of the intended ability to place it anywhere on the grid and individually for each preset.
Appreciate your reply. Good point you make there. I didn’t really think about the option of putting the looper between the QC and the amp. Duh, makes total sense. Thanks.
