I recently added the artist presets in Darkglass. I can see them all from the drop down. I can select them but once I select one I can no longer access the drop down menu again. If I want to change presets I have remove the plugin from the channel and re-add it. Once I select one, it’s locked again. Anyone else see this. I’m running Pro Tools 12. Thanks!
Hello @lbarragan1964. Are you running the latest version of Darkglass ultra? You can download the 3.0.0 version from here: https://neuraldsp.com/downloads/
If you keep having the same issue, please contact support@neuraldsp.com.
Thanks! I will check the version I’m running. I knew it had to be something simple.
LB
