Export/import presets between different DAWs
I am using Darkglass Ultra and Parallax on Logic Pro X. My studio engineer is using another DAW. is it possible to export and import presets for the Darkglass plug-in from Logic to another DAW? If so, what menu is used for this?
Thanks!
Hey @bjelkeman. You could export the presets created within the plugin and then import them on another computer. Just press the magnifying glass icon to open the plugin folder, or locate it manually: < User Folder > / Library / Application Support / Neural DSP /
Once you have the preset files, you can import them by drag-and-drop over the GUI, by pressing the Import icon, or by copying each file into the preset folder.
