Would be great to be able to create your own IRs using the QC alone, without the use of a computer and audio editor, in a process similar to a capture: impulse signal sent by the QC, mic return signal recorded, trimmed and normalized automatically by the QC, and voilà!
I think you can already capture a Cab, might not be an exact IR, but those I heard were fine
IRs may most likely require less computing power than a full neural capture. On the computer I use a chirp of some seconds to capture IRs. But It is an annoying process with many manual steps. Would be great if QC would feature an automatic IR capture.
If you want to capture a cab only a clean solid state amp is best to retain the character of the cab.
