a way to monitor the capture results and reference tone through an IR, while still in capture mode, it would mitigate needing to use external gear to load an IR. capturing preamps directly i’m monitoring through a HX stomp for the IR, if you could load up an IR to run the A/B comparison through while in capture mode you could do it all with QC
