CorOS Version: 1.1.0
When in stomp mode led for stomp button D is lit as if it has toggled on an effect block but it doesn’t seem to be assigned to a block and if you push it more than once the screen gets filled with colored lines and the QC is frozen, only removing power will reset it. Also, the asterisk in the preset name appears after any changes are made to the preset but toggling back to the default state of the preset does not remove the asterisk.
I have re-downloaded to overwrite the preset but the problem persists. No sign of the problem in any other preset I’ve tried. I suspect the preset has some corrupt data?
