Copy Scene cancel assigned to a switch
Hard cancel switch to cancel scene copy. Can’t bend over in the middle of a show to cancel a scene copy if you did it by mistake.
Also make the length of time to inact scene copy .5 to 1 second longer.
I like this but also feel it should just be taken off the preset switches altogether. It would be fine in the “3 dots” menu for me.
There is a recommendation for this back in March.
You could finish the copy and then just press undo.
I feel like the OP addressed that? It would be easier to reach down and cancel the copy but his point was–and I had this happen again this weekend–sometimes you’re in the middle of something and can’t crouch down to cancel or undo. I just played through until I had time to cancel the copy, but wasn’t able to use the scene I’d set for the solo…after the song was over I reached down to cancel it. It’s pretty annoying. Again, my vote is just take it off those switches altogether.
Had the issue at least twice in the last show we did. Extremely annoying.
Why not have e.g. the tap tempo switch as a universal “back”, “cancel” or “escape” switch for the various editing functions including in particular “copy scene”. Alternatives would be to have some sort of copy protecting mode which could be activated when playing live or to extend the time a long-press needs to activate the copy function…
V<
I agree completely.
