There is a way to work with scene mode, and using a midi controller turn the effects blocks on and off. Example: Scene What is a clean if I connect a rotary or a tremolo via the controller?
Yes in Scene Mode you can switch from a scene where for instance a block, on the grid, containing a distortion pedal is off to a different scene where it is on.
Or. Using Stomp Mode you directly control the block on/off with the foot switches. You can assign a block to botton in it’s control panel by pressing the foot icon and then a button.
I personally is the Hybrid Mode with the top four buttons assigned to scenes and the botttom 4 directly to blocks. Usually E&F are overdrives G&H various mods.
Hope that helps and welcome!
