CorOS Version: 3.0
Describe your issue:
App crashes or will not load on mac
- I have tried switching the usb
- I have tried restarting mac and quad
- I have tried using on factory presets
CorOS Version: 3.0
I would suggest adding as much detail as possible (ie. OS version, hub or no hub, OEM power, MAC specs etc.) Also, you may want to email support@neuraldsp.com so that they can log your issue and hopefully provide resolution.
It’s a very known issue people have been reporting ever since it came out. NDSP has repeatedly tried and failed to fix it. Which you could read about on this forum if threads wouldn’t be deleted all the time.
That’s right @747 & @richierich333 That’s true. I love the quad cortex and control. Is the best that have been made for guitar processing… I love the product, every bit of it. Give it 10 out of 10. But It would be all 12/10 without CC would work. Hope they soon find the solution. Or just take back the releasing and give it out agin when It works.
But when you are getting used to working with CC it’s a hassel going back… Hope they find the solution to make this all perfect.
