Configurable MIDI response matrix
One way to improve the MIDI implementation would be to include something like a MIDI matrix where any incoming MIDI controller message could be routed to any parameter in the current preset. The functionality would also require a MIDI learn option and a MIDI monitor to be able to see what the QC is fed with.
This right here!
While the current MIDI control options may suffice for standard usage, having only two expression midi sources to map per preset / secene as well as lacking a morph feature as seen in Kemper amps, makes the QC lack a lot in terms of live automation.
I really hope that they add a way to use all the unmapped MIDI CC messages.
Exactly two expression midi sources is just not enough. 16 or more would be a start!
One should be able to define these for each preset once, so that each preset is automatically mapped and one only needs to “midi learn” each “knob” once. Then there needs to be some UI view to see the labels of these 16. It would help if the labels of those knobs could also be sent over MIDI (e.g. sysex and/or MCU protocol).
This is similar to this request - MIDI Learn - we all should vote for the request.
It would really also help to be able to change the assigned channel and cc # for the reserved midi messages here: MIDI Reserved CC List
Weirdly MIDI out can be configured, but not MIDI in.
Plus support not just assignment of 2 expression knobs with MIDI, but way more parameters per preset.
