Right now, when connected to my Mac, I can see that the only sample rate available is 48kHz.
Is it possible to change that on the QT itself?
Or will it be a possible option later on to support other sample rates?
The QC is locked to 48 kHz and can only provide that clock speed as an audio interface.
That said, my unit clocks fine slaved to 44.1 kHz as an aggregated audio interface with an RME UCX as clock master on my Mac mini. However it’s officially out of spec and not supported by NDSP.
understood that is it’s current capability… I would love to see it be able to support other rates too. Fairly standard functionality for an audio interface.
Unless you are categorically stating that it’s physically not ever possible for the QC, in which case, bummer.
Look at any other hardware modeler. Helix, Axe FX III, QC are all fixed at a sample rate (mostly 48l). If you change the sample rate to 96 then all the DSP on board would drastically change. You would have way less DSP on these units if they operated at 96 vs 48, etc. Makes sense they would optimize them for one sample rate.
