Re amping in 44khz
Am I right in thinking this isn’t possible? Only in 48k?
As far as the spec says - only 48 kHz! The QC USB Audio Interface sampling rate is fixed at 48 kHz, which means re-amping over the analogue connections for other sampling rates.
But it’s still possible to reamp in 44khz if I use analog connections?
Assuming I can it’ll negate the need to buy a reamp box as I figure I can capture my amp via my two notes captor x and then reamp via QC. Hope so at least
Thanks
If you reamp using the analogue connections you don’t need to care about the QC sampling rate as the signals you transfer between the QC and the DAW audio interface are analogue.
