I need to toggle between amps in scene mode, but they are the only thing I can’t seem to get to change.
All the other blocks changes will save except amps. (I turn one on, it never toggles off, and vice versa)
Can I not do this?
It works fine for me…Make sure your amps in the scene both have the four dots beside the “power” button when you pull up the amp knob screen (long press on this button to get that indicator). As an example, you should be able to select amp A to be on in Scene D and off in Scene E and the opposite for amp B.
I made a tutorial video for new users…maybe there’s some other tips that will help you out!
I missed the long press. Thanks for the video!
