Touchscreen is cool and all but I’d like to be able to simply browse through devices by turning a knob without navigating through the ‘change device’ menu. It is laborious and makes it more difficult to select and compare sounds quickly. The way this is implemented on Line6 M5 etc. is great.
You can do this today, turn the upper right encoder inside the block edit screen (tap the block) is there something more/different you’re looking for?
Is it possible for the volume button to do this?
Ah ha! So you can! Thanks for pointing this out, that’s great.
