hi. I think if you want to change your tape delay (for example) to another delay it should be a tad easier. so if you click on the three dots it happens as it does now where you get all the options. I think if you click on the name of the device there should just be a pop up menu that shows you instantly with this one button press the other type of delay on offer.
If you use the top right encoder knob, you can scroll through like components.
Example: select a drive block then just turn the top right encoder knob to cycle through all the drives etc.
I use this to audition cabs, amps, captures, drives, chorus, reverbs, cabs and delays all the time etc.
excellent thanks. will give it a go.
Excellent, you will love it!
