Capturing Mantra Signal Chain for live vocal use
Curious if anyone has tried capturing Mantra plugin for live vocal use on QC yet ? I would love to know the results. I realize it cant do the delays, reverb or pitch effects but these can be recreated mostly. It should in theory be able to do the pre-amp , complex eq and compression chain dialed in for your vocal and mic used however..
I captured all the capturable devices separately, they’re on my Cloud account, same user name as here. I’ve also got them built into a preset meant to simulate the Mantra layout
Probably going to reshoot the compressors again with V2
Wow thats awesome ! Ill check it out.. Definitely worth doing again with the multiband compression going on again I would think. Did you find it helpful for live vocals ?
haven’t had a chance to experiment yet- I just figured I may as well layout the template for when we get time. Keep in mind, if you do try the template preset, it’s not dialed in at all= everything is set to defaults. It’s just meant as a starting place with all the tools gathered.
