Hi guys,
I can’t launch any plugin, they all crash instantly as i want to open them.
Does someone know what is happening?
Thank you!
Hi @alex10n , I would definitely email support@neuraldsp.com so they can work with you and ultimately help in determining the resolution. It appears you are running MACos? If so, there may be more variables for compatibility related issues but it’s best to work with support to log and resolve.
Did you ever figure out what the problem was?
@alex10n - I had the same problem once, also on MacOS. After MacOS update I did not update iLOK software/drivers. Took me two days to find it was causing the problems.
Just in case - check iLok for updates.
