Cannot enable the Tempo Led
CorOS Version: 1.4
Describe your issue:
When I siwtch the Led Light to enabled in the Tempo Screen, nothing happens,
The Tempo LED remains dark.
  1. Tap Tempo/ choose Tempo in Action Menu
  2. Turn Led from Off to On (or on->off->on)
  3. The Tempo Led stays dark
I expected this to happen:
When I siwtch the Led Light to enabled in the Tempo Screen, the Led should start blinking
  • I have tried rebooting
  • I have tried switching between global/preset/scene mode
  • I have tried changing overall brightness
Hi @simonfloris , please enable MIDI over USB and your tempo LED light will start working again.
Hi, yes, thank you, I found out by now, that this is the current workaround, again.
Isn’t this a regression from 1 3.2? Are you adding tests for this?
Regards,
Simon
I have received notice that the NDSP development team is aware of the bug which will be resolved in a future update. Thanks!
