Midi Clock Light on QC
Hi all,
Updated my QC to 3.2.0 today.
At rehearsal I noticed that when receiving midi clock the tempo light no longer flashes blue and in tempo but stays green and on whatever is the default tempo. However all the midi commands were working fine and all were in time. Guitarist hasn’t updated his QC yet and it still getting the blue light.
Is this a feature that’s been removed in the update or a little bug?
I have the same issue, after installing the latest version. I assume it’s a bug.
Hi.
I had a look at Device Settings/MIDI Settings and Enable MIDI clock in is Disabled. I cannot test it at home, I have to go to our rehearsal place, but this will most probably fix the issue.
Thanks Pepi, I’ll have a look at that.
I had the same issue after updating firmware. I believe the Midi Clock in setting in the system settings was switched back to default (off). Switching that back should resolve your issue, as it did for me.
Can confirm on my end as well switching on resolves that LED issue.
