Can you globally turn off input noise gate?
Dumb question…is there a way to globally turn off the noise gate that is on the inputs of all factory presets? Looking for a global way to do this rather than tap the input and disable it for each preset.
there’s no Global way to do that yet
Please God YESS!
The Noise gate is killing the tone on ALL the presets. And I use Strats, Teles and humbuckered guitars. I don’t get it. Gate is a dynamic “effect” that should be used on individual presets that needs gating, not set as a fixed default.
( Anyways, what Jeff Bezos rocket fuel output does these demo guitars at NDSP have that makes this default gate setting a smooth one? )
As @xush indicated, there is no global option currently. The gate on the inputs is dynamic and controlled per preset. If using the factory presets, your only option is to save the preset you want to modify within your user directory then disable the gates. I haven’t had much of any issues with the gates, I would also recommend to review your impedance setting (Global) and adjust as needed. Otherwise, saving into your user presets is the only work-around currently.
