Can you change the output of the tuner without bending down?
I use a Strat into output 1 and a Les Paul into output 2.
I was wondering if there is anyway of switching the tuner between the two outputs without bending down to the floor to do it manually. I am very old and the less bending down I have to do in a gig (or any time really) the better.
If there isn’t, then I suggest there should be. The whole point of me buy this thing is so i can stop lugging valve amps around and lead an easy life. This little bug bare isn’t helping.
Thank You
have you tried the setting where it reads both inputs?
Assuming you meant ‘inputs’ ? Like @xush stated, configuring the tuner for both inputs will solve your issue.
Thanks for the help. I didn’t realise you could set them both.
Cheers for the help.
