How to connect two instuments which also go to different outputs
I play guitar and bass for various songs in my band. How can I connect both so that my bass goes to one output (my bass amp) and my guitar to another output (my guitar amp)? Ideally I want to have a set-up for my bass and a different one for my guitar, so that between songs I can switch instruments easily and they both play through their own amps
In the QC user manual there is a section “Setup examples” which also contains an example how to connect two guitars and bass wit separate inputs and outputs.
The example puts all instruments into one preset, but you can use the same principle to make separate presets for bass and guitar each using their respective inputs and outputs.
Thanks, I’ll have a look
I had a look. It helps in terms of having more than one input going to the same monitor, but I want the instruments going to different live amp speaker set ups (not virtual ones). Maybe some external mixer?
Maybe I’m missing something, but-
What do you need besides
guitar to Input 1 > Output 1 to guitar amp
Bass to Input 2 > Output 2 to bass amp
You can substitute outputs 3/4 if you need to use different cable types. If you need additional outputs going to other places, you can use the FX Sends in each Lane
Thank you and apologies, I’m so stupid. I could only see outputs 1/2 and 3/4, I didn’t scroll down to find the separate outputs. All is now perfect. What a brilliant box!
