Some modellers I have owned in the past have allowed me to toggle a foot switch A/ B which has been useful say, for when I want to switch from Fender clean / Marshall core tones… I am sure you can do this with splitters too but I want to know whether the foot switches can be configured to toggle … or not. I cannot see evidence of this is the manual.
Thanks all
Huh? You can program the amp sims to change with a foot switch on the QC, yes. If you’re asking about toggling an amp channel, then you would need an additional device since the QC doesn’t toggle amp switches on a physical amp.
Ok thanks for that, I’ll try again…. Some modellers allow a single foot switch to have a dual role… for example the default setting might be a Fender DLX, and when the same foot switch is pressed again, the foot switch toggles to a second amp, say a Marshall… same foot switch different amp. I recall the old Atomic AF12 had this dual configuration capability which basically doubled the flexibility of the foot switch.
Hope that’s clearer.
You could certainly do that using Scenes but it would require two footswitches.
Yes this is possible afaik. Assign both amps to the same switch. Manually turn one of them off by clicking on it and hitting the bypass button. Now that switch will toggle those two amps.
