CA John's 2c Ch3 SHRED toggle bug
CorOS Version: 2.3.1
Describe your issue:
In scene mode, toggling the shred switch on and off between scenes (say scene 1 toggle = off and 2 toggle is on) pauses sound output for half a second.
1: Create a simple patch with this amp model and any cab.
2: Assign toggle as I described above
3: Fails every time, also after restarting the device, using different cabs makes no difference.
I expected this to happen:
In scene mode flawless switching between scenes and block settings.
Not much to try, it just happens.
It’s not a bug, they explained that was normal behavior for that amp
Ok, where can I find that description, do you know?
Please read through the dev logs, I think this was covered in an early one.
