Using focusrite scarlett 3 solo for interface. Nolly, Abasi, Plini all worked, and plini is working right now. When I start omega, and use Omega out of the box, after setting the correct ASIO input settings, I get no sound.
I do get sound when switching from mono to stereo, but only the right channel. This is for every preset.
Hi @nanthil. Try disabling the input you’re not using from the Audio Settings.
You’re right, its the mic input. I’m hearing that in the left channel.
I’ll have to figure out how to disable that.
Switching the omega ASIO to only use input 2 solved the stereo problem. Not a problem with omega then, its a problem with me not knowing how to use my interface
again
